Blown head gasket Farmall b n ?
showdown
I adjusted my governor today run it down the road.Then saw. Fulid running out the radiator cap , and white gray smoke coming from the stack.
Guess I lost the head gasket? Nay thoughs?
(quoted from post at 03:04:17 07/01/15) I adjusted my governor today run it down the road.Then saw. Fulid running out the radiator cap , and white gray smoke coming from the stack.
sounds about right. You can order a new one from this site, or Napa. Make sure you adjust the valve lash after you install the new gasket. Youll want to retorque the head bolts after about 3 -5 running hours..
