Zaddison
Will a John Deere A turn 16.9/38s in first gear 4500 to 5500lbs class 5.75 by 6.75 murphys pistons, head,roller rockers and manifold with a dengler cam. Would like to know before I put them on. Thanks, Zeb
Lots of unknowns here. Cut tires or uncut tires? 18" hitch or 20" hitch? 48" or less sled chain or one long enough to chain your tractor to your trailer? Tight clay track with lots of moisture or loose and dry? Best case you'll have 60 hp, more likely low-mid 50's HP. Uncut tires, 18" hitch, 48" chain and average track conditions it'll be a maybe at 5500 lbs.
Mike
