johndeeregreg
i do some occasional pulling with a 730 john deere. max hitch height around here is 20". with my draw bar at the 20" max i can only go 2nd gear with out running out of power, but i always spin out. always have had the bar in as far as i can get it and the front end gets light so i dont see any advantage to lengthening the bar.
so i have been wondering if i were to turn my bar over to the down side which would probably put me in the 15 to 16" range would i be able to run 3rd gear and lug the engine down more and with the increased speed get me farther? it is roughly a 1 mph jump from 2nd to 3rd.
depending on the speed limit of the class i may have to hold the throttle back in 3rd till i get lugged down or am spinning enough to slow me down below limit.
dirt track, transfer sled. 7500 and 8500 farm stock classes. some times 8500 and 9500 when i use my 720 diesel but have the same issue
let me know if anyone has tried such an idea or if you think its a bad plan.
there is a pull tomorrow sunday the 17th in Preston MN that i am thinking about going to and thought i would bounce the thought off some more experienced pullers so i have an idea weather to try it or not.
thanks
thanks
