bhshot
First time pulling my farmall M this year. I was wondering what a good air pressure to run in the rear tires. 13 6 38.
I would start with 9 PSI have somebody watch them when you are at your hardest pull point and go from there. If you have a hump in the center you need more air. If it rounded out at bottom to much. The goal is to have a flat bottom in your ruts then you are about right.
