C-264 filler rings
770puller
Finally figured out what's in my w-6 it's a 248 with out sleeves and a 4" bore anyone make filler rings for the top of the counter bore ? Thinking maybe that's why it blew a head gasket any insight would be awesome thanks!
Any machine shop should be able to make rings, but you need them pressed in, then bored, and the top milled down flush with the deck. Lost of machine work aka money.
Murphy's makes a big bore gasket that fits around the sleeve counterbore. Might be a lot cheaper solution.
