filling tires???
56oliver
Looking to add more weight to the front of my super 77.... where i pull they wont let you add any suitcase weights or wheel weights unless they are made for that tractor and origional. how much weight would filling just the front tires add. has anyone ever done this?
Thanks
A 6.00-16 with CACL mixed in the water will add around 80lbs to each tire as per a NAA ford manual I have
You can buy a adapter to put water in them out of your hose. I used to do that but you have to drain in winter which isn't to bad but once you do that there will always be some water left in them if you want to get lighter.
