Fuel pressure to an m carb?
770puller
How much pressure is acceptable I'm thinking like 3-4 lbs since it is a single barrel on stock rpm, also what kind of flow will keep the bowl full under full load ?
the stock gravity feed system works fine if their are no restrictions in it what kind of horsepower are you making that will determine how much fuel flow you will need
Was going to put an aluminum fuel tank out front, it's on a w6 so trying to move alittle weight to the nose since it's so short wheel based
