Have you pulled with the 11-36 on yet. If not i would try them first pulling to see the power you have with them. If you are what gear are you in and do you spin out or power out. It will take more power to turn the 12- 38.
Yes I have been pulling with this c for three years depending on the track I spin out. Put over size pistons in shaved the head. Pull in 3500 class.
Are you in 2 gear in the 3500 class or 1. If you are spinning out a taller tire like the 12-38 is like a 1/2 a gear and will help you put the power to the ground better. Also if you can what are you running for fuel. I run vp-c14 in my tractor and was able to go in one higher gear just by useing that fuel.I didnt believe a guy that told me about it and it was a big differnce in pulling.Its not cheap tho but the fuel makes horse power.
There is a guy in durand Wisconsin phone is 715 590 3589 that sells it and other fuels. He has 5 gal pails for $82. I can get about 2 to 3 pulls on that but that also depends on how many tractors are in line. The fuel seem to also make the tractor run cooler. Im sold on it if you have a high compresson motor it will add more hp. It will even help some that are built up just alittle vp c16 also works good. At the pumps around here you only can 92 octain gas and it dont cut it.
