Electric Water Pump ?
On some engines can save a lot of weight. If have water in just head, can put water in back of head and take out front and run as cool as before. Also can cool between pulls without running engine.
The small 12 volt water pump at harbor freight is all I run ...same pump as some high performance ppl try to sell ya!
5 gal a minute from harbor freight is fine. But if you put the water in right under where you take it out won't work well with low volume.
