VicS
Location
SE Il.
Took D17 flywheel to a balancer.(CWT) Flywheel only from a 426 AC. stock 47.08 force in lbs. at 3000. 130.79 at 5000. final spin 2.07 at 3000. 5.56 at 5000. Then put the pressure plate on the balanced flywheel. (7.3 powerstroke pressure plate) 65.87 force in lbs. at 3000 rpm. 182.97 at 5000. worse than the flywheel. He said finds them way off all the time. Final spin 2.20 lbs force at 3000. 6.10 at 5000. 24.41 at 10000. less than stock at 2000- 29.28. Stock at 10000 731.89lb. Th
