southern ill rules,
bock
went up to 1970 on the year , 2 barrel carbs. and will have a turbo class 10 mph ,2500 rpm , 354 cubic inch limit , with3lm turbo max, aluminum front rims in all div, and will have a stock tractor class no cut tires 18 in. drawbar, hope somebody wrote down all the rule changes to keep it all straight we are hoping too get more pullers too show up by opening up the classes
I hope it don't bring less tractors if we cant run with them I will pull other places. When you get to 70s you are going to be running against some big cube motors. Time will tell.
1970 and older in 6 and 8 mph only, Aluminum front rim in 4mph farm stock and mod. No rear aluminum in farm stock, other farm stock uncut tires and 3 mph.
