Farmall C lightening ideas
PretendFarmer
Our Farmall C currently weighs 2610 lbs with no driver. Id like to shed about 250# so it can go into the 2500# class that one of our clubs runs.
My first thought is tin wheels. Any other suggestions? and where would I get such tin wheels and hubs?
At that light you would be just getting in
to the class with no movable weight!
Chances are your results wold Not be worth
your effort!
Cliff S
Tin wheels front and rear - if you can go tubeless that save a lot of weight - if you want to hand crank it take the starter and battery out - might lose weight by fabricating lighter seat and steering wheel support.
Pray tell,having a really low -- low gear helps make a small tractor weigh less !!!!!! you just can't make this stuff up. LOL
