WD checking the camshaft timing
I had a pulling cam ground for my WD Allis. I want to degree the cam, but the cam card has all the specifications except the intake center line degree. There is a lobe separation of 108 degrees specification. Do I use that for the center line degree or do I leave it stock timing?
Call the place where the cam was ground and have them specify the "ideal" intake centerline for your engine/application/cam.
If the cam was designed for your engine, then the cam grinder should be able to specify the intake centerline for installation. If it is a "cookie cutter" grind that "should work", then you may not get additional information.
It is risky (for a grinder) to rely on the stock timing marks for proper cam timing. I have seen up to 15 degrees of error on stock cam timing marks (on Continental engines). That is why degreeing a cam is always a good idea.
Regards,
Goldsburg
Surely not! I bet they will suggest 105 to 106*. This is as important as the grind. if it isn't timed right the grind does not work.
I agree that's why you always degree a cam in!
The last WC cam I done that had a 108 centerline I degreed in at 105 on a 240 cube engine.
Cliff S
