M1
cliff im putting a 140 head on a 123 but the valves are longer then the super c head.they are 5 15/64 putting a tisco kit in will i have problems with them hitting the pistons.Thank you
You shouldn't have any problems!
What did your block come from? Super C?
You can call me at 570-220-2726
Cliff S
it came from a farmall 200 how much do you think i can shave the head if it hasnt been resurrfaced. I pulled with you at rome PA thanks again.
I wouldn't take more than .075 off it!
Is it the stock 200 head?
There is a better head!
But read your rules first!
I'm sorry I forgot that you are a have a better head working with someone else the same time without a better head!
Most of my tractors with the same head only have.060 off the head not to sacrifice the reliability of the head and that gives you 8.8 to 1 compression that you can run on 87 octane and there's not much more than 9.0 to 1 to gain by taking more off!
Cliff S
