DAVE Thompson jr
At waseon Ohio this year my tractor was not running like it should have been. Found the problem in the carbuerator and repaired it. While it was in my garage I decided to do a cylnder leak down test. It has 2 percent or less in 3 cylnders and one that is 5 percent. When I replaced the beearings last year i could see that the cylnder walls looked perfect at the bottom. ANyways when I rebuilt the carbuerator I took my bore scope and the top of the cylnders pistons and everything look like new. I looked at the valves and they are seating like they should be and I cant see anything wrong. The camera on the bore scope shows everything. The clylder that is high on leak down I cant find anything wrong with. Would you guys tear in to it or leave it alone.
