Super C cylinder head
Bob0465
Since I will be sending my Super C cylinder head to the machine shop anyway, is there anything I should have done as this is a tractor I use for tractor pulling?
get you some pistons that go into that pocket on the head and get the compression up to 11 or more to one .
That is probably the one thing I can do that will make the most difference (3-1/4" sleeves & pistons of course). Will probably have to go 12 volt with that kind if compression.
Thanks,
Bob
most likely a after market starter. it will be near 300 static compression and 110 will be needed .
