carburetor for Farmall 230 with 153 engine
Hi guys I just picked up a 153 engine to put in my 230 and wondering if someone can point me in the right direction as to what carburetor works best with a 153 in a 230 for pulling. this is my first post on this site and i am sure many more to come as i get farther into this swap!
Good Morning!
I have a Super C that has a 153 in it and I pull it whenever I get a chance!
I am using a 140 style manifold and a revamped Zenith carb from a 140
The 230 manifold should be the same as the 140 and the carb too.
My carb has been jetted and the venturi has been opened up also.
It makes around the 42 HP mark.
yes,a 504 intake belongs on that motor.the 153 was in the 504 tractor,and the combine.but the 230 manifold will work on the 153,you can bore the ports to fit the head and 504 carb,and slit the bolt on holes to accept the 504 carb.
What carb is on the 230 engine?
Does it have the adjustable main jet
I have a zenith carb on mine with a 18mm venturi and I can adjust the fuel to it with a thumb screw.
I also run a Carter carb and the Venturi is open up to 3/4 of a in and I am not sure of the jet size but I can check.
Email me if you want
[email protected]
