cockshutt 570 starter
I have a 570 with a hercules in it that is bored and stroked with high compression. I need a starter that will hold up to it. The starter is mounted on the left side as you"re sitting on the tractor. Any help locating a starter or info on what will work is appreciated
I bet the Diesel starter would work but it is a heavy cuss. A GTA5.6 Hercules was 10:1 stock and those starters are a little smaller so that might be an option.
I made a plate to use a gear reduction starter that we use for are 88 oliver you can call me 812-432-5581 home or cell 812-707-9336
