DC case piston help
3208 oliver
New User
I'm looking for a set of new or used 4 or 4.25 inch dome top pistons for my DC case any help or leads would b appreciated thanks
(quoted from post at 07:53:47 10/09/14) I'm looking for a set of new or used 4 or 4.25 inch dome top pistons for my DC case any help or leads would b appreciated thanks
The DC block will not take 4.25" sleeves without boring for a larger OD sleeve, the old 4.0625 sleeve was very thin. This was made by M&W and that kit was popup and long gone from production and very difficult to find.
If you are willing to pay for block work 4.375 would be very comfortable and 4.625 doable but for pulling only. If you want 4 " popups have them made.
John Salei can supply the 4" flat tops as Case installed in later DCs. I presume that you want to pull by your request for popups.
I don't know if DonL from this forum has any takeouts from M&W but you could check.
mEl
(quoted from post at 16:53:47 10/09/14) I'm looking for a set of new or used 4 or 4.25 inch dome top pistons for my DC case any help or leads would b appreciated thanks
I have a place where you can get brand new 4 1/16 Pistons and sleeves made if you are interested. Prices three years ago was 150 each for sleeves and 1000 for four Pistons milled brand new out of aluminum.
