460 tillage 3rd gear
anybody have the tillage gear that speeds up 3rd gear just a tad....or know of any part or cast # so i can try to find one at some salvage yards..thanks everyone
Why would you want to gear down? Just run 2od and turn the rpms to it? What sise tires are you running? You can change ground speed with tire sise if needed.
Running 15.5-38...want to gear down because we are limited rpm and it only slows it down .5 mph...but it makes a bunch of difference believe it or not...thanks for seeing the classified add...already talked to him
i beleive the 460 and 560 have a triangle stamped on the serial tag. that means they came with the heavier tillage gears
burnt-smta has it right cc is tillage gears. The triangle stamp means it got the updated bearings and gears after the recall for rearend failures.
