PretendFarmer
I have a chance to swap my 11.2's for 13.6's on my low geared H. I have to keep my 10-38 rims. Which way would you all go? The 11.2's might lay down better on the 10-38 rims but the 13.6's are bigger.
(quoted from post at 04:08:20 10/01/14) C,I knew you would not take advice,very apparent in your posts.you only hurt yourself !!!!!!!!!!!!!!!the proof is in your name.
(quoted from post at 16:30:20 09/30/14) And as another has added,tire pressure is your friend.Judging the track is more important than any tire,tractor set up and driving skill will win more pulls than tires alone.
(quoted from post at 00:54:34 10/02/14) PRETENNDfARMER,CAN WE KISS AND MAKE UP,I JUST HATE GOING TO BED KNOWING YOU ARE UPSET.MAN UP,MAKE YOUR OWN CHOICES,YOU HAVE 5 OTHER'S OPINIONS,ALL DIFFERENT,which one could help you,GOD HELPS THOSE WHO helps themselves.I gave you good advice,but you do not care,just bad mouth!!!!!!!!!! jeez,I never thought that you might listen to anyone,just keep asking till someone agrees with you.
