tazz01
New User
quick ? if you could only afford to do one thing to your engine to increase hp what would you do first
no such thing as only one thing,many little free stuff,plus what the others mention,the big three,Compression,stroke and displacement,cam and carb,oh that's more!!!!!!!!
air flow--no matter how -- I sandblasted out the intake -- increased the intake of the head with a little machining and more sandblasting --bored the venturi to twice its original size took the oil out of the air cleaner -- 10 hp gain -- 45 to 55 on a m farmall -- Good luck -- Roy
There's nothing at all cheap about a properly turbo charged engine! And if you turbo a larger engine you still get more hp than turboing a small engine so yes, NO replacement for cubic inches. Simple physics :)
