Putting pressed steel wheels on the front of my M... how?
R Weld
I want to put pressed Steel wheels on the front of my 48 Farmall M...other than swapping my entire NF out of for a later model IH, did M&W or someone make an adaptor so that you could run pressed steel wheels on the original NFs? How are most of you doing it?
I have a set of hubs from a 460 that can go on there with the proper bearings. If you have a good parts store with a bearing book it's easy. Will sell for $75 plus shipping they could fit in a flat rate box.
get out the welder and fab up a lower bolster using stub spindles.
Just changing from cast hubs to pressed steel hubs and rims wont loose enough weight to make it worth while.
