I've been pondering the idea of putting a 350 chevy in a farmall m for pulling, I have a motor from when I raced dirt track that's new with no laps on it, it's a 350, .060 over steel crank, scat rods, flat top pistons.the blocks been decked, and the entire rotating assemble had been weight matched and balanced. There is a class around me that has a 410ci limit and must be a small block , iron block and straight plug iron heads And run msd ignition with a 8000 rpm rev chip. 750 carb max and must be stock.And no sheet metal intakes. My question is.if any of someone could point me in the right direction on the cam,intake and head setup. Thank you, george
