Shawn W
Question for the farmall guys.
Can I bore an H block big enough to put an overbore 350 M&W piston with sleeve in it?
good H blocks can handle 3.75 bore with no hard block. that is the spec on the 350 sleeve OD. 350s had the biggest bore from factory with no overbore option.
If you can find a good 350 block bore it and run without sleeves. You can also use thin sleeves like they put in bad cylinder in a car.
