jdrich
Anyone know of any 5010 deeres that pull 9500 farmstock? I think it could be a tough non turbo tractor.
Should not be too hard to get it there, a guy around here pulls one in the 9000 and 10000 pound non turbo class. You may as well use a 619 engine and remove turbo and start stripping weight off of tractor. You may have still have tough competition with molines with the 800 engine. The superfarm guys are getting these tractors into 9300 should it should not be an issue.
There is a few that try to pull 10000 and 12000 NA around here. Easy to get them down light. Most use a combine axle on the front. But a 3208 V8 Cat in a Oliver is what generally wins. Their 3 speed torque is the reason. There is a Moline that tries but has to be a diesel. So he has a 585 cu. maybe bigger. the rules say 650 cu. and 3500 rpm. Just right for a cat 636 cu. Actually a 650 cu in IHC 466 is there also.
