super 88 build
kwf
Looking to build an oliver super 88, not to wild. Super 88 has 3.375 rod journal. Thinking of off set grinding crank to 2 and use 77 rods. Should i just get a 3.875 piston and sleeve kit, install both or bore those sleeves to 4, but what pistons to use with 77 rods, or is there another sleeve and piston that would work with 77 rods. Thanks for any help.
i believe a super 88 has 2and 7/16 journal , m,w piston kit will work with that set up and 77 rods you will need to shave top of pistons a little there was a article in antique puller that Bobby Hinton did that was this particular build
