unstyled B pistons
J Arbaugh
New User
What is good piston to use in 37B would like to go .125 over standard. Thanks for good suggestions.call 304-890-3626
J WD-9 pistons are .150 over and have more compression height. I think they will make you around 6:1. Have to make bushings for the wrist pin. Super WD-9"s are .250 over. Lynn
I just sold some Moline 4 5/8" pistons to a fellow that was telling me he was going to put them in a JD model B. Dont know if that helps but I have lots of MM parts to sell. Jeff 308-940-0255
Pistons and crank from a 1938-1947 un-styled are sometimes dropped in. Bore the block approx 250 thou.
More displacement,more compression and more power with cheap parts from somebody's scrap pile.
Jeff the block bored out nice and picked up some aluminum 4 1/2 x 1" round blocks from McMaster . Will post some pics when the parts come in .
