Allis 7020 Steering
SteveGr
I put a narrow front end on this tractor. The front that I used was from a 4020 JD. The problem I have is that it will turn one way and not the other. Either hard right or if I switch hoses left. The steering control valve was just checked and is fine. When hooked to a double acting cylinder it works fine. It should work, what gives.
