Tractor Pull! Saturday, june 14th Goodhue, Mn @ 11AM
tentis48M
South Eastern Minnesota Tractor Pullers
S.E.A.T.P
Tractor pull Saturday June 14th Goodhue MN.
Pull starts at 11a.m. so be early to sign up for classes.
Tractor Pull is located at 21869 370th St Goodue, MN 55027 . ((((((((Pull is at Bruce Dankers Farm.)))))))
Classes
-Farmstock classes- 4500, 5000, 5500, 6500, 7500, 8500, 9500, 10500, 12500, and 13,500
-Improved Farm stock classes- 4500 5000 5500 6500 7500 8500 9500 10500 12500 13500
-Sportsman classes 4500-9500# NON TURBO
-Sportsman Turbo. heavy class (After Chores)- 10500-13500#
All Genral Rules apply. any questions concerning the pull or class rules reply to this post and I will get back to you as soon as possible. or contact Bruce Dankers @ 651-380-3134
Thank You! Hope to see you there!
sportsman non turbo 4500-9500# class rules.
drivers must be 14 years of age or older . those under 18 years of age must have written parental/gaurdian permission.
tractors must have working kill switch.
drawbars must not exceed 20 inches in height or be less then 18 inches from center of axle to hooking point. no part of draw bar may extend rearward beyond point of hook. Draw bars must be stationary in all directions no clevises. Top of hitch adjuster cannot be above center line of axle or hub.
weights must not extend rearward beyond rear tires and cannot be more then 11 feet from the center of the rear axle to the furthest point forward.
maximum tire size is 18.4x38 any rim width, no radial tires no steel wheel tires, two wheel drive only. press steel rims allowed. no duals, cut tires are allowed.
rpms allowed will be determined by the SEATP rpm chart. any tractor not listed will use manufactures data. a 10 % margin of error will be permitted. all tractors to have positive throttle stops with a working governor in the stock location.
any gear. speed limit is 3.5 mph, to be checked by radar. shifting of TA is allowed. one beep after flag/cone will result in disqualification.
tractors manufatured to use diesel fuel only cannot be converted to gas or LP. tractors must naturally aspirated. no turbos or blowers except Oliver 99 GM etc.
Tractors must have the stock engine,frames,transmission, rear end, and axle housings or manufactures replacement. stock heads and there replacements are to remain unchanged in outside apperence. no 7 bold main blocks in olivers, no 12 port heads, no 99 heads, no 1600 series heads. Allis Ahalmers- WC/WD/WD45 can use D-17 engine, IH H-350 and M to 450, JD A/B/G can use power blocks, No M-M 800 heads or blocks. dual exausht not allowed except after stock manifold.
Enhanced electrical systems permited. no rev limiters allowed.
only stock appearing manifold and carburaters are allowed. no increased height in any tractors (i.e.,Deck plates, shims,girdels ) exept for stock gasket.
Massey 55, IH w-9,ih wk-40, case LA, Case 600,Moline GB, moline BFD, Oliver 99, and all like size tractors are not allowed below 5500# class
http://www.mapquest.com/maps?address=21869%20370th%20St&city=Goodhue&state=MN&zipcode=55027
pulling Track is dirt.
