Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Blackburn cam
Bill Riechmann
06-01-2014 12:38:41
Josh did my cam and carb on a 49 JD G. Great results!
2 Cylinder
06-01-2014 17:16:52
 Re: Blackburn cam in reply to Bill Riechmann, 06-01-2014 12:38:41
What were the numbers on the G? And is it stock stroke? What bore size? I have a fairly stock 67 hp G. No stroking, flat head, aluminum high compression .090 over. How much could I gain with a cam setup?
Josh Blackburn
06-02-2014 08:54:28
 Re: Blackburn cam in reply to 2 Cylinder, 06-01-2014 17:16:52
Cam and carb work would be worth. 8-10 hp.
2 Cylinder
06-02-2014 14:27:34
 Re: Blackburn cam in reply to Josh Blackburn, 06-02-2014 08:54:28
What kind of price for the cam & carb work Josh?
Josh Blackburn
06-02-2014 14:28:27
 Re: Blackburn cam in reply to 2 Cylinder, 06-02-2014 14:27:34
9892775366
Early B
06-02-2014 09:31:34
Hey Josh, should i tell them what my little B that you built is putting out on the dyno? lol I did find a few more horses playing w/the carb since we last spoke.
Gtx1967jewison
06-02-2014 18:42:14
 Re: Blackburn cam in reply to Early B, 06-02-2014 09:31:34
Did you stroke it?
Early B
06-02-2014 19:41:55
 Re: Blackburn cam in reply to Gtx1967jewison, 06-02-2014 18:42:14
Yes i have a little stroke. 52 hp at the crank, what you figer that should be at the pto for hp?
Gtx1967jewison
06-03-2014 17:59:38
 Re: Blackburn cam in reply to Early B, 06-02-2014 19:41:55
Should only be about 3 hp less, but I would not try it because it will break the pto
Early B
06-03-2014 19:23:25
 Re: Blackburn cam in reply to Gtx1967jewison, 06-03-2014 17:59:38
I wouldnt worrey about it brakeing @ 52 hp.
Gtx1967jewison
06-05-2014 14:34:49
 Re: Blackburn cam in reply to Early B, 06-03-2014 19:23:25
Lots of bone stock ones have broke. When it goes you end up with a hole in the bottom of the Trans case.
