TractorLinks.com
Blackburn cam
jpick87
06-01-2014 12:11:08
I put one of Josh's cams in my A and man that thing pulls better now. It's a completely different beast now. I've only got 4 passes with the new cam but it's running really strong. Price was reasonable turn around was quick and Josh is super nice to talk to. Just thought I would pass along some good feedback for everyone.
Thanks a million Josh!
Gtx1967jewison
06-01-2014 20:09:50
 Re: Blackburn cam in reply to jpick87, 06-01-2014 12:11:08
We have a stock stroke 5" B with his cam that pulls real hard on the top end. I just finished a stock stroke 4.69" B with the same compression & valve size, & a "puller" cam grind from another shop that does not pull nearly as hard. They both idle real nice. There are a few other differences, but those may get eliminated soon. It carries the front in 2nd gear for about 50', in 6500# class, with 750# 11 feet ahead of the axle. It's 220 cubes.
Gtx1967jewison
06-01-2014 20:11:39
 Re: Blackburn cam in reply to Gtx1967jewison, 06-01-2014 20:09:50
52hp on the crankshaft, on a belt driven Prony Brake that is dead accurate.
Josh Blackburn
06-01-2014 16:24:58
Thanks guys. Glad I could help. Just had a customer give me some Dyno results on one of his projects. Stock stroke 730 gas with .125 over bore, cam and carb I bored for him pulling 79 hp and still not quite rich enough.
Gtx1967jewison
06-01-2014 20:01:44
 Re: Blackburn cam in reply to Josh Blackburn, 06-01-2014 16:24:58
I've wondered if opening the tight spot in the Venturi causes enough reduction in velocity/vacuum that it has trouble pulling enough fuel up? A bigger carb would not have this issue because the size difference between the Venturi & throat is still greater, Unless it was severely oversized. Any thoughts?
north puller
06-01-2014 16:48:10
What compression ratio? That's an impressive number.
Josh Blackburn
06-01-2014 17:47:56
 Re: Blackburn cam in reply to north puller, 06-01-2014 16:48:10
10.5
Bill Riechmann
06-01-2014 12:38:41
Josh did my cam and carb on a 49 JD G. Great results!
2 Cylinder
06-01-2014 17:16:52
 Re: Blackburn cam in reply to Bill Riechmann, 06-01-2014 12:38:41
What were the numbers on the G? And is it stock stroke? What bore size? I have a fairly stock 67 hp G. No stroking, flat head, aluminum high compression .090 over. How much could I gain with a cam setup?
Josh Blackburn
06-02-2014 08:54:28
 Re: Blackburn cam in reply to 2 Cylinder, 06-01-2014 17:16:52
Cam and carb work would be worth. 8-10 hp.
2 Cylinder
06-02-2014 14:27:34
 Re: Blackburn cam in reply to Josh Blackburn, 06-02-2014 08:54:28
What kind of price for the cam & carb work Josh?
Josh Blackburn
06-02-2014 14:28:27
 Re: Blackburn cam in reply to 2 Cylinder, 06-02-2014 14:27:34
9892775366
Early B
06-02-2014 09:31:34
Hey Josh, should i tell them what my little B that you built is putting out on the dyno? lol I did find a few more horses playing w/the carb since we last spoke.
Gtx1967jewison
06-02-2014 18:42:14
 Re: Blackburn cam in reply to Early B, 06-02-2014 09:31:34
Did you stroke it?
Early B
06-02-2014 19:41:55
 Re: Blackburn cam in reply to Gtx1967jewison, 06-02-2014 18:42:14
Yes i have a little stroke. 52 hp at the crank, what you figer that should be at the pto for hp?
Gtx1967jewison
06-03-2014 17:59:38
 Re: Blackburn cam in reply to Early B, 06-02-2014 19:41:55
Should only be about 3 hp less, but I would not try it because it will break the pto
Early B
06-03-2014 19:23:25
 Re: Blackburn cam in reply to Gtx1967jewison, 06-03-2014 17:59:38
I wouldnt worrey about it brakeing @ 52 hp.
Gtx1967jewison
06-05-2014 14:34:49
 Re: Blackburn cam in reply to Early B, 06-03-2014 19:23:25
Lots of bone stock ones have broke. When it goes you end up with a hole in the bottom of the Trans case.
