Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
John Deere A weight
Bill Marcusky
06-01-2014 10:36:16
I have a 1950 JD A that with the tires loaded and cast center wheels without me on it weighed 6500lbs. Add me and its almost 6800. I removed the cast centers and installed JD 9 bolt wheels and unloaded the tires. Im hoping to get down to 5600. Will I be close?
720 puller
06-01-2014 18:17:51
 Re: John Deere A weight in reply to Bill Marcusky, 06-01-2014 10:36:16
I used to pull a 1952 A with pressed steel and 15.5 tires. It weighed 4945 lbs. with me on it (200 lbs.) Still had rockshaft and pto in it and my front weight bracket and wheeliebars weighed 120 lbs.
D beatty
06-01-2014 17:56:53
If you have 14.9 X 38's on it you will drop 1,118 lbs. by pumping off fluid.
2 Cylinder
06-01-2014 11:25:12
You should be there. I had a 47 A, with pressed wheels, flat back cover, non roll-o-matic down to 4500.
Bill Marcusky
06-01-2014 12:54:59
 Re: John Deere A weight in reply to 2 Cylinder, 06-01-2014 11:25:12
Was your 47 A one with the flat plate frame rails or the cyclone pressed steel frame? Also my club doesn't allow an A below 5000. So if I get there I ll be beyond happy
2 Cylinder
06-01-2014 17:09:43
 Re: John Deere A weight in reply to Bill Marcusky, 06-01-2014 12:54:59
If U unload the tires & use pressed wheels U should be below 5000, which would give U movable weight. Yes the 47 had the pressed frame rails, but still had the high, low transmission.
jdrich
06-01-2014 11:31:22
Just unload the tires. That should have gotten you there
