Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: farmall head
johndeerered
05-26-2014 19:50:40
i will try that, i don't know the chamber sizes or what compression it would be, but the depth of the chambers look shallower,
dblair
05-27-2014 05:28:12
 Re: farmall head in reply to johndeerered, 05-26-2014 19:50:40
the lp head cc is 140 the 8060 head is 200 if you know the cc of the dome the compression ratio is no problem .
johndeerered
05-27-2014 12:44:58
 Re: farmall head in reply to dblair, 05-27-2014 05:28:12
I thought the 362433r1 head was a gas head, with bigger chambers than propane, but smaller than an 8060 but im not sure, that would be to much compression if it is a 140 cc chamber. I had 97 lbs. with 8777 head before, i will try to do the ccs on it and see what i come up with, thanks again.
dblair
05-27-2014 14:28:34
 Re: farmall head in reply to johndeerered, 05-27-2014 12:44:58
gas head is 180 and the 364586r1 is the lp head if your going to buy a head buy the lp repo on ebay . get the cr over 10 to 1 . cr with a gas head and 40 cc dome is 7.9 about 195 static and practically no help on Horse power .
johndeerered
05-27-2014 17:28:02
 Re: farmall head in reply to dblair, 05-27-2014 14:28:34
Thanks for all the info, i"m not buying a head i have the 8060 and 362433 head already, put new sleeves and rings and had the cam redone at bullitt cam, just wondering which head would be the best, the tractor is only used for pulling, don"t want to get comp high enough to have problems, just pull better, maybe beat a john deere or two.
dblair
05-27-2014 14:20:07
it will be 223 lbs at 8.34 and a lot more than that at 10.3
north puller
05-27-2014 07:58:08
Don't forget the gasket. Adds about 8-10cc to the chamber volume.
