Oliver Guru's
Anonymous-0
I would like to build an Oliver 88 engine. Would like to use the original looking parts on the outside. (Block, manifolds, and carb. I would like to get around 150hp at 10-20 percent over on Rpm's. Is this possible? What would be a good combination to make this possible. If it is possible. What would be the limiting factors if not possible? Thanks!!!
i have a 88 complete 541 cin around 200hp at 10% the tractor is natpa leagel 18-4-38 cut firestone ,speed meeter and weight to get to 6500 runs, 3 or 4 gear 12,500.00
