Looking for a Thompson Rock It Governor
BBinOk
If anyone has one or knows where I can get one that will work on a M thru 450 farmall give me a call. 405 410-7850
just curious what will it do for you ? it won't add an ounce of power and with a tighter spring yours will respond a lot better .
They do make a difference when you get into the modified engines. Response and control is everything. You don"t understand the idea of 4 weights verses 2 weights.
Dave could you tell me the differences on a two or a four wt. gov.i guess the rocket is a two wt.also why is the rocket better.Thanks for your help.
im with you i cant see how governors make power , when i pull the throttle is in my hand and i control rpm of engine
My Dyno tells me that on a stock tractor a Thompson Rock-It will get to peak horsepower at a higher RPM than a rebuilt stock one. In Dyno we trust... well at least when it comes to measuring horsepower.
