JD D pistons
Try calling Ray at extreme tractor parts. You can also have Jeff make you some at Murphy's . I'm guessing $650-800 a set from either place, with pins & rings.
That is what I'm finding. Nobody has anything. Just hoped someone had line on a set. From what I was told is that they only make a .250 over size and you turn it down to what you need.
(quoted from post at 16:46:49 05/04/14) That is what I'm finding. Nobody has anything. Just hoped someone had line on a set. From what I was told is that they only make a .250 over size and you turn it down to what you need.
I can get std, .045, .090, .125, .250 High Comp Piston sets for 800$ Shipping.
If your interested give me a call.
Thanks!
Derek Holdren
Holdren Machine & Repair
Colton, SD
605-446-3251
(quoted from post at 14:09:29 05/06/14)
Thanks!
Derek Holdren
Colton, SD
605-446-3251
Very interested in a set of your pistons. If possible give me a call 318-453-0571.
