Yesterday's Tractor Co.
Shop Now View Cart
Re: John Deere 404 to 466 engine swap
4010 puller
04-25-2014 15:22:55
Should be a pretty well bolt in deal. 1st thing I would check is the bolt holes in engine block where it bolt thru the frame. The 404 is 1/2" NC, make sure the 466 is the same way, I think some 4640 and 4840"s are 5/8" NC which would require modifying the frame which prob would not be worth it as a 4440 engine would be more of a direct bolt in. Tranny/clutch should handle it if you leave engine stock. Not sure on sheetmetal. I don"t know if intercooler will be in way on left side of hood or not, the same for the turbo, may go right in or may have to do some fabricating.
04-25-2014 16:17:32
 Re: John Deere 404 to 466 engine swap in reply to 4010 puller, 04-25-2014 15:22:55
a 4440 jd is a 466 a 4430 is a 404 with a bosch pump. Regards John
