valve springs
lil mac
I need to replace the valve springs on a on a farmall 340-C135 head. I would prefer a slightly stiffer spring than original non rotating. Any suggestions what to use and where available.
Give me your installed height of the valve spring, valve travel and what you want for spring diameter and I can tell you what spring, retainer and keeper package you can use.
I recently purchased a IH valve overhaul kit order # A403161-0403. As I was removing the head I realized it did not have rotating exhaust valves. Can I return the short springs and get 4 of the regular (longer) springs? We are trying to get done for the next tractor pull ASAP and need these before I can proceed. B
