2nd A block
Mark Fulmer
New User
Has anyone on here hard blocked a two cyl block ? I have a 6-1power block that is cracked at the head between the cylinders and leaks into both cylinders .I'm thinking of putting in water pipes and hard blocking. Can you fill a block a third or half full or do have to fill it full because of uneven heat distribution. Dose the block have to be magnafluxed
I did years ago tractor locked up at end of pull then when it cooled down it started back up.Never ran it again. could you post pictures? I may be able to help
