TractorLinks.com
Re: JD 2520
buickanddeere
04-03-2014 06:48:32
Not even close. The Dubuque and Waterloo engines at most shared alternators, fuel filters, and green paint.
The even though a 2510/2520 is a early 3020 and side console 3020. The bell housing bolt pattern and the front engine mounts are totally different.
Iirc the 4030 used a Dubuque engine too. Actually most of the new tractors with 3, r and 6 cylinder engines up to 414cu" and approaching 200HP. They all run Dubuque engines in the Waterloo chassis.
high octane
04-03-2014 07:51:37
 Re: JD 2520 in reply to buickanddeere, 04-03-2014 06:48:32
thanks. ya, years ago we had an early 400 hoe. had the automatic forward n reverse with the twin gear shift. after going thru the hyd system, it was a real good machine in warm weather. then we got this 300, n engine was rough. dad got it goin n used it, sold the 400, n used this lil 300 for years. its spun a rod, have to rebuild the crank, but block has been repaired, like they broke front end off at one time. hard to find a block here.
