Gas tank insert for H Farmall--Gary Baker or anyone
redcub
I was told that Gary Baker had inserts for H Farmall gas tanks. Mine is rusted inside. I would like to cut the current tank and put an insert or fuel cell inside. I want a long term low maintenance fix. Gary or anyone have a solution that doesn"t involve rocks, ball bearings and such for an H Farmall?
(quoted from post at 11:55:39 03/21/14) I was told that Gary Baker had inserts for H Farmall gas tanks. Mine is rusted inside. I would like to cut the current tank and put an insert or fuel cell inside. I want a long term low maintenance fix. Gary or anyone have a solution that doesn"t involve rocks, ball bearings and such for an H Farmall?
Muriatic acid. I don't like putting rocks or assorted hardware in a gas tank either.
Find a steam cleaner stick the nozzle in the tank with the trigger locked and let it boil awile then they make a liner that you can dump in there shake it around and that should take care of your problem.
I have pulled tractors with you before. Take the tank off and get it to my house or my dads and I will get the Gas tank cleaned for you. It wont cost you anything. It wont have any paint but will be clean.
I didnt think Dave was talking about the Red Cub i know from our pulling days in TN Eagleville the last pull i rembember you won the class with that high tire press you pulling or restoring?
we put a used R134 keg in a dc Case tank, holds about 3.5 gallons, probably wouldn't work in a Farmall very good
That was a good day. We didn't have the most HP but we did have the perfect set up for that concrete track! My H has been down for 3 years--started with a spun rod bearing. Hope to have it back together this week. Planning on bringing it back to Eagleville this year.
