TractorLinks.com
Re: Prepping for a few hours on the dyno
Dave Thompson jr.
03-13-2014 15:18:33
Ive built a few of them just like what you have. they had an 8060 head that isn't the best and roller rockers and some milled off of the head so it was flat with a little work done to the carbuerator. Make sure the gear on the camshaft hasn't ruined the cam before you go back together from the pump putting a load on it. I always warm them up on the dyno then re torque the head and check for leaks. Then run the heck out of it and see what it will hold at 540 rpms on the dyno by adjusting timing and adjusting the carbuerator. At Caterpillar our engines go to full load as soon as they start on the dyno.
shawnm
03-14-2014 06:23:45
 Re: Prepping for a few hours on the dyno in reply to Dave Thompson jr., 03-13-2014 15:18:33
What do you mean by the gear ruining the cam? What causes this?
What type of oil should I run for the initial break in? Standard 15w40?
Dave Thompson jr.
03-14-2014 15:46:26
 Re: Prepping for a few hours on the dyno in reply to shawnm, 03-14-2014 06:23:45
If you are using a cam that has been in a tractor with hydraulics the pump puts a load on the gear on the front of the camshaft it is a taper fit. It works loose and lets the gear wobble. Its a common problem. Just make sure you have a good cam and one that the nut tightens the opposite direction. It is a very simple engine you are building. Just torque everything and check everything over good. Retorque the head after it is hot then run the heck out of it. You will Make around 65 hp. at 540 rpms on the dyno. I run rotella t 1540 in my tractors. Find some good 14.9 tires and you are ready to go and win. My uncle has my old super m in Florida now pulling and is having fun and enjoying life at the pulls.
