Farmall 450 and a MSD 6al-2
Anonymous-0
So i have wired everything the way the direction show..... The tractor won't start....Im using electronic ign. As well....I disconnected the orange and black wire that's in the loom from the MSD box and the white wire...then the tractor started...the coil was pretty warm as well when all wire were connected.... What am I doing wrong
I had same problem with the set up if u wired it like a points set up some piece burns out in the box but if u wire it like a crank trigger it wont... when you install the msd you need to signal the box with the distributer with electronic ign .... so the msd box thinks its a crank trigger set up .. there fore use the wiring diagram for a crank trigger set up ...fixed my problems I gopt my infro from an msd tech man in bowling green ohio when I was having problems and had my box check there at the event by them ....hope this helps
Hey there shaggy I'm in hinckley I've tried everything tonight I think but no sucess.... Give me a shout tom I'll be hauling corn all day..... 8157395814
