TractorLinks.com
Re: 65 HP block
mlpankey
03-13-2014 07:48:04
Arc flat head.
clampdaddy
03-13-2014 08:07:01
 Re: 65 HP block in reply to mlpankey, 03-13-2014 07:48:04
Thanks, just checked them out. Seems like the runner volume would be way more than the gap between the block and the head would allow. How would you check your flow numbers on a set up like that? Install the head to the block and then do your testing?
This post was edited by clampdaddy at 08:07:55 03/13/14.
mlpankey
03-13-2014 13:43:57
 Re: 65 HP block in reply to clampdaddy, 03-13-2014 08:07:01
Yes head has to be on it
clampdaddy
03-13-2014 14:51:41
 Re: 65 HP block in reply to mlpankey, 03-13-2014 13:43:57
So do you do any, for the lack of a better term, "port work" to the bottom of the head to compliment any work done to the runners?
mlpankey
03-13-2014 19:05:25
 Re: 65 HP block in reply to clampdaddy, 03-13-2014 14:51:41
The block and head has none of my port work. The sleeve came loose on louis while on the dyno . We do alot of sleeve repair work when sleeve is installed incorrectly or just moves around for any reason thats why its pictured in my power hone.
