Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: 65 HP block
mlpankey
03-13-2014 05:52:19
If your wondering about me I am as real of a person as that litttle 29 cubic inch motor making 2.24 hp per cubic inch . If you look at intake port and intake valve pocketand seat youll see the port and valve size that makes it produce 2.24 hp per cubic inch is close to if not the same size as port and valves used in tractor heads that produce .24 to .30 hp per cubic inch. As the pontiac commercials bigger is better. 3.54 bore 3 inch stroke
clampdaddy
03-13-2014 06:07:09
 Re: 65 HP block in reply to mlpankey, 03-13-2014 05:52:19
I'd really like to see the bottom of the head. Seems like to get any flow through ports that big, the head would have to be really tall combustion chamber would have to be huge, as would the pop-up on the piston.
mlpankey
03-13-2014 07:48:04
 Re: 65 HP block in reply to clampdaddy, 03-13-2014 06:07:09
Arc flat head.
clampdaddy
03-13-2014 08:07:01
 Re: 65 HP block in reply to mlpankey, 03-13-2014 07:48:04
Thanks, just checked them out. Seems like the runner volume would be way more than the gap between the block and the head would allow. How would you check your flow numbers on a set up like that? Install the head to the block and then do your testing?
This post was edited by clampdaddy at 08:07:55 03/13/14.
mlpankey
03-13-2014 13:43:57
 Re: 65 HP block in reply to clampdaddy, 03-13-2014 08:07:01
Yes head has to be on it
clampdaddy
03-13-2014 14:51:41
 Re: 65 HP block in reply to mlpankey, 03-13-2014 13:43:57
So do you do any, for the lack of a better term, "port work" to the bottom of the head to compliment any work done to the runners?
mlpankey
03-13-2014 19:05:25
 Re: 65 HP block in reply to clampdaddy, 03-13-2014 14:51:41
The block and head has none of my port work. The sleeve came loose on louis while on the dyno . We do alot of sleeve repair work when sleeve is installed incorrectly or just moves around for any reason thats why its pictured in my power hone.
