TractorLinks.com
Re: Farmall 450 and a MSD 6al-2
IHSMOKE
03-12-2014 22:02:18
I had same problem with the set up if u wired it like a points set up some piece burns out in the box but if u wire it like a crank trigger it wont... when you install the msd you need to signal the box with the distributer with electronic ign .... so the msd box thinks its a crank trigger set up .. there fore use the wiring diagram for a crank trigger set up ...fixed my problems I gopt my infro from an msd tech man in bowling green ohio when I was having problems and had my box check there at the event by them ....hope this helps
