Yesterday's Tractor Co. Restoration Quality Tractor Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
65 HP block
MLPANKEY
03-12-2014 15:56:12
98.68.173.191
[URL=http://s738.photobucket.com/user/pankeyc/media/photobucket-16513-1394580719631_zps81c91306.jpg.html][/URL] 3.54 bore
[Reply]   [No Email]
mlpankey
03-13-2014 05:52:19
152.85.8.38
 Re: 65 HP block in reply to MLPANKEY, 03-12-2014 15:56:12
If your wondering about me I am as real of a person as that litttle 29 cubic inch motor making 2.24 hp per cubic inch . If you look at intake port and intake valve pocketand seat youll see the port and valve size that makes it produce 2.24 hp per cubic inch is close to if not the same size as port and valves used in tractor heads that produce .24 to .30 hp per cubic inch. As the pontiac commercials bigger is better. 3.54 bore 3 inch stroke
[Reply]  [No Email]
clampdaddy
03-13-2014 06:07:09
198.228.217.147
 Re: 65 HP block in reply to mlpankey, 03-13-2014 05:52:19
I'd really like to see the bottom of the head. Seems like to get any flow through ports that big, the head would have to be really tall combustion chamber would have to be huge, as would the pop-up on the piston.
[Reply]  [No Email]
mlpankey
03-13-2014 07:48:04
152.85.8.38
 Re: 65 HP block in reply to clampdaddy, 03-13-2014 06:07:09
Arc flat head.
[Reply]  [No Email]
clampdaddy
03-13-2014 08:07:01
198.228.217.163
 Re: 65 HP block in reply to mlpankey, 03-13-2014 07:48:04
Thanks, just checked them out. Seems like the runner volume would be way more than the gap between the block and the head would allow. How would you check your flow numbers on a set up like that? Install the head to the block and then do your testing?
This post was edited by clampdaddy at 08:07:55 03/13/14.
[Reply]  [No Email]
mlpankey
03-13-2014 13:43:57
98.68.191.152
 Re: 65 HP block in reply to clampdaddy, 03-13-2014 08:07:01
Yes head has to be on it
[Reply]  [No Email]
clampdaddy
03-13-2014 14:51:41
198.228.217.170
 Re: 65 HP block in reply to mlpankey, 03-13-2014 13:43:57
So do you do any, for the lack of a better term, "port work" to the bottom of the head to compliment any work done to the runners?
[Reply]  [No Email]
mlpankey
03-13-2014 19:05:25
98.68.191.152
 Re: 65 HP block in reply to clampdaddy, 03-13-2014 14:51:41
The block and head has none of my port work. The sleeve came loose on louis while on the dyno . We do alot of sleeve repair work when sleeve is installed incorrectly or just moves around for any reason thats why its pictured in my power hone.
[Reply]  [No Email]
Dwaine
03-12-2014 16:20:02
70.208.195.160
What block is that
[Reply]  [No Email]
mlpankey
03-12-2014 16:25:08
98.68.173.191
 Re: 65 HP block in reply to Dwaine, 03-12-2014 16:20:02
7.90 sniper extreme
[Reply]  [No Email]
Smoking Minnie
03-12-2014 16:56:30
174.241.192.79
 Re: 65 HP block in reply to mlpankey, 03-12-2014 16:25:08
Pankey's 6.5 hp briggs
[Reply]  [No Email]
MLPANKEY
03-12-2014 17:02:27
98.68.173.191
 Re: 65 HP block in reply to Smoking Minnie, 03-12-2014 16:56:30
Quoting Removed, click Modern View to see it's shiny aluminum!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
