Yesterday's Tractor Co.
Shop Now View Cart
Re: How about a 900cid 4cyl for Natpa?
jd plowboy
03-09-2014 19:08:23
you can bet it will be bad a$$
Underdog Moline
03-10-2014 11:08:33
 Re: How about a 900cid 4cyl for Natpa? in reply to jd plowboy, 03-09-2014 19:08:23
That is only .55 HP/CI if/when it cranks out 500hp
Figure the new LSX has about .58 HP/CI and that is N/A
The 5.9 hemi .99 hp/ci the 6.2 is 1.16
Even a 1988 Dodge caravan with a 2.5L 4 cylinder was at .65 HP/CI
That means that it can be less efficient than a 1988 Caravan and conservatively make 500 HP!
OK one more just so I am being fair the 1985 Chevy Chevette was 97.7ci and 70hp giving it a .71 HP/CI not sure if that makes the Chevette better than the caravan or i have just confused everyone
03-10-2014 11:18:43
 Re: How about a 900cid 4cyl for Natpa? in reply to Underdog Moline, 03-10-2014 11:08:33
We're making around 7hp per cube. Highly boosted 505 cid engine with an efficient cylinder head. But we're running at about 7 atmosphere's of pressure in the intake at the valve.
So does that mean it's 1hp per cube naturally aspirated on a 505 cid engine? It's not uncommon at all.
It comes down to how much air you can pack in a cylinder. Making the engine bigger isn't the answer if you can't feed it.
I love that intake setup!!
This post was edited by wi50 at 11:19:17 03/10/14.
03-10-2014 11:36:53
 Re: How about a 900cid 4cyl for Natpa? in reply to wi50, 03-10-2014 11:18:43
I don't claim 500hp! Lol I do think 290-300 ish is more than realistic. Thanks Marty the aluminum is much easier to work with making the intakes. Plus its purty
