Wheel spacers for 9 bolt wheels
Noforddon
Does anyone make a aluminum wheel spacers for 9 bolt hubs? This would be a spacer to move your tires and wheels out away from the tractor, a little bit, like you would need with a weld on hub.
I've got a set of cast iron ones made by underverth Never seen aluminum ones but I'm sure someone can make them.
(quoted from post at 12:25:13 03/09/14) Does anyone make a aluminum wheel spacers for 9 bolt hubs? This would be a spacer to move your tires and wheels out away from the tractor, a little bit, like you would need with a weld on hub.
I can make some... Cnc laser cut
[email protected]
